KoolBreeze420
In the KTM50 world more resistance is better, means more winds in the coils or they haven't melted together yet, so it should make more spark energy with the higher resistance one I'm assuming.
I was assuming the same thing that higher or better ohms could create better spark but my worry is if this is true and it's supposed to be between 3 and 400 ohms will it be to strong?
One other thing could a loose spark plug cause the magneto to fail?
I was riding around yesterday on the way home ran into some wet weather as I got home she lost power backfired and quit. So of course I immediately suspected my newest waterproofing failed turns out, I was wrong the problem was simply that the spark plug vibrated loose causing the bike to stall no harm has come to it I tested everything and she's fine. But brought the question can this situation + a little water or moisture cause a magneto to short?
Thoughts anyone?
I think I am not tightening the spark plug enough unless this is something that happens and that after each time I stop the bike I should check the spark plug to stop further failures. I did get a few rides out of her yesterday it was the 1st day that I really got to ride her for any length of time. I made sure not to go over 30 minutes but did get at least 3 30 min rides before the plug vibrated loose enough to stall. The end of the muffler also vibrated loose and came off, I was lucky enough to notice and found it and have put it back on and am going to have to make a checklist of things to check, before each ride and after each stop like going to the store. I Can say I have learned lots since I got this damn thing, but many things would have gotten by me without this forum and all who take time to read and answer question's so thank-you all.
