carb problem
hobesounder
I have a NT carb, the barrel inside the carb won't slide using the throttle unless the carb is on a angle. any suggestions Thanks!!
If this a new carb. remove the slide an clean the debris out of the carb, any small amount will cause it to hang up. also be sure to put the slide back in correctly.
Is your throttle cable being kinked when the carburetor sets straight up? If so, reroute it so it doesn't.
As the posts above suggests, the slide, or barrel, will only work if installed correctly. There are two slots in the sides of the barrel. The short one goes to the left as you look down at the carb. The long slot to the right. It can be forced in 180 degrees out but it won't work.
If the other suggestions fail, you can try using some 360 grit sand paper to smoothen up the slide. That was the only fix for my friends bike.
