can't get started
ktbreezo
:-||can't get started checked spark plug to see if it got spark it got none.what's the problem? anybody know the answer?
How did you try to check for spark? Not trying to insult your intelligene, maybe you were doing it wrong. Sounds like your CDI might have went south! Or maybe your sparkplugwire broke.. like where it goes into your CDI?
First, remove the kill switch then try again, they are notoriously bad.
Second, double check all connections, and make sure the plug wire is screwed into the CDI and that the metal bits inside the cap are in there and in place, they come apart, and should probably be replaced with a good spark plug cap and wire anyway.
Let us know what you get.
got similar thing goin on hard to start an runs incosistantly good bad some days even between rides wire was lloose in top of spark plug cap pushed it back in but still same prob ya no if ya can fix it replacin cap or just buy neww cdi wat ya recon mates
