Evan
Well, the rear studs broke off flush with my motor. It started running weird and when I looked down the motor was kinda flopping around. So i don't know if a wire come loose causing it to miss and then shake causing the stud to break or the other way around....or ???. right now i'm having no luck drilling into the stud to try and extract it. I'm going to get a new bit and see if that works. In the meantime any thought or suggestions. I used blue locktite on the studs. also the wire connections to the coil seemed fine when i took the motor off...don't know how to tell about the plug wire itself which is stock as is everything else. The studs were made from all thread from Fastenall. Thanks
Evan
Evan
er is not. It is by far the easiest method for removing these.
