Big mistake. The red has no use on a motorized bicycle. Save it for when you're working on earth moving machines.i use the red high temp which is 450*f
Why do you want to weld the muffler bracket? I have installed dozens of those and so long as you have the right sized muffler bracket they hold just fine as is and you aren't stuck with a fixed mount which you may really regret some day.So the next thing I want to do is weld the piece the u bolt goes through on the sbp front mount to frame and it should be ready to go.
That looks like a helicoil repair, it should work just dandy.Why do you want to weld the muffler bracket? I have installed dozens of those and so long as you have the right sized muffler bracket they hold just fine as is and you aren't stuck with a fixed mount which you may really regret some day.
That bracket you have looks pretty big, is that why you want to weld it?
That would be silly, muffler brackets are a $3 item at the auto parts store and come in any size you want so just get one that exactly fits your down tube.
Sick bikes sales 2 size Z brackets for the front mount. One is for smaller muffler clamps (1 3/8 to 1 1/4" , the other for larger ones (1 1/2 to 2"), but both accept a range of U bolts, hence the angled slot on each side for the muffler clamp.You are correct sir, the exhaust clamp that came with the mount is too big, and the smallest one they carry, which is the 1-3/8" exhaust clamp. If I where to get a small exhaust clamp that would make the U bolt smaller, so would I need to do any modifications the other bracket that bolts to the motor?
