I wasn't planning to install a new exhaust today. In fact I was planning to go on my first really long ride on the Cadillac. I would of been gone all day. Before heading out, I decided I'd give it a wash job. Washing your bike is a good way to check it all over to see if anything is going wrong.
Almost right away I noticed the muffler was breaking apart at a weld between the header and the muffler. About 12 hours later I was testing riding this.
I bought this SBP Ex chamber last year. I never installed it because it looked too difficult, and I was happy with the stock modified pipe I had. In the last few weeks I've held it up to the Cadillac a couple of times, and decided it wouldn't fit very well, and put it back in the box.
The Cadillac has a really narrow BB spindle. Holding the pipe in the perfect position under the BB, the little muffler on the end of the chamber wouldn't fit between the crank, and the tire. Aiming out the right side, it had to be too low in order to clear the right side chain, and sprocket.
I got the idea to use the stock header, because of the way it broke off. After figuring out I couldn't go under the BB, I looked at going high on either side. I didn't like that, so that just leaves the back of the bike.
The one metal I can weld is copper, so most of my pipe is copper. All I did was decide where to mount the muffler, and then extend the header to it. Placing the muffler outlet low, and back by the rear axle has appeal from a noise standpoint. I'm guessing a longer header isn't better for performance, but it is what it is.
This is my first report after 1 test ride,
I was very surprised by how quite it sounds. WOW. To bad the motor makes so much noise. There's a spot around 6500 rpm where it sounds like someone dropped a fork in the garbage disposal omg.
I could feel a noticeable improvement in the bottom end and mid range. The top end which was pretty darn good before, is still good, maybe a little better. Part of the way was uphill, and it was accelerating nicely when I let off the throttle at about 36 or 38. It's always felt like it will do about 40 but I'm afraid it will blow up doing it. Now it'll just blow of faster.
The actual feel of the bike seemed a little different riding. The center of gravity may be a little lower. The weight of the muffler isn't supported by the engine now either, so I'm hoping the exhaust will become more dependable now. The muffler is mounted in 2 places.
Next I'll paint the whole thing BBQ black.
This exhaust was as much about just seeing what's possible as making an exhaust.
