bike's performance has changed
deacon
minor bike philosopher
Jan 15, 2008
8,114
8
north carolina
The last couple of days the bike has started a little differently. Now for one thing it's hot as heck outside so maybe it's nothing but still thought I would mention it.
It takes a little farther to start the bike not much just a little. It runs a little ragged for about a block, then smooths out. It never did that before, it doesn't seem to want to take the gas at first.
My thought is I probably should check the spark plug tomorrow. Most likely it is fouled. I run it as they say, but who knows. I had turned the idle down the other day so I turned it back up this morning but I haven't started it since.
Do these things idle high in the summer or something.
Bikeguy Joe
Jan 8, 2008
11,837
247
up north now
Your plug may be causing your problems. I would say that since your weedwacker engine is small, a change in humidity and/or temp will make it operate a little differently.
Remember, hotter, more humid air has less oxygen in it so it will actually make you engine run richer.
deacon
Jan 15, 2008
8,114
8
north carolina
Its the china bike and come to think of in addition to that the air is full of smoke from a forest fire down east. I am going to check the plug but it might not be anything at all but weather conditions.
the whacker over heated for sure. I have a lot of things set up wrong. The drive wheel is too big and the spring tension is too much I think. The drive can't skip so it is heating the engine. Even though the throttle moves nothing changes. I am pretty sure I have stressed the engine.
deacon
Jan 15, 2008
8,114
8
north carolina
If i lift the engine with the scientific clutch rod(lol) the engine races so I'm pretty sure I have over stressed it.
