bikebug
ssmc12
i just picked up an old bikebug bicycle..while taking off the fuel line with the primerbulb the nozzle or jet (not sure of the proper term) that goes into the primer base plate fell off and vanished..can anyone tell me where to find another?
Hi. A lot of lawn equipment came with primer setups. You might check with a local shop, you might get lucky and connect with a parts guy who is willing to search his stock for one that might fit. If you can come up with rough dimensions from the old one it will help. BTW, I have a bikebug. It's one of the older ones with a fuel pump, so it doesn't need a primer bulb. Mine has a small Keihin carburetor-looks like a 10mm. What does yours have? I need to clean my fuel tank with vinegar and install a new in-tank filter before I can run it, but with good compression and good spark, it should fire right up.
