AaronF
So I recently got a new kit installed on my bike it ran great for two days.I changed the plug wire to a higher quality 7mm it ran good for about 30 minutes and then sputtered and shut off..Went ahead and switched the wire back to stock,motor running good for a couple of blocks around the neighborhood it wouldn't start back up!I let my MB sit for awhile take it for ride and it still shuts down and will not start up I repeated this process several times.I've tried several different spark plugs (even though) its getting a good spark,plug is gapped at 20.Noticed today there was something black running through my fuel line,so I found out it was black paint chipped from the gas tank going through my fuel into the carburetor.Could this have clogged the main jet or caused worse? Need your help Norman! Thanks
