Bmonette8385
So I'm searched around the threads and haven't been able to find exactly the answer I'm looking for. I'm a bit confused. Lets say(because I don't know the choke in/out part) with my filter off I see the little hole with the pin in it for the choke. I put the choke lever to it most slack position and the pin is down. with the choke lever pulled to its most taught position the pin is up. from what i can gather, with the pin down, it stops air from going into the hole. Or does it create a venturi and pull some "extra" fuel? I have to pull the pin( clutch level taught) when I go up hills. don't know if that will help. I'm open to any and all feed back! Thanks guys!
