Hi I am an authorized SBP dealer but I am not a total expert. If you have the tapered shaft Huasheng engine that means you have the widest 4G it is 3/4 wider than the 4G with the 5/8 shaft. There is a chance you could still use it with the shifter kit but I am not completely positive as I have not done it my self.
I have heard that you can use the SBP shifter kit with SBP's bottom bracket and the wide crank arms from the grubee 3 piece wide crank set and you just might have enough room to do it. BUT as I said I have not done this my self so I don't know if it will or will not work. You will have to do some heavy investigation as to weather this can be done my gut says yes but I have nothing to loose you do.
Good luck and please let me know what you find out
Terry
Terry
