wayne z
I boutght this kit with Titan motor from BGF and I was ready to recieve the Hoot gearbox I thought I saw in the E-bay ad, and try my hand at hardening, indexing and shimming the gears.
I got the single #25 chainbox instead. What a letdown. the gears hafta be stronger than this thing!
Anyways, When I pulled the cover, I discovered that they had assembled this box with 15mm internal toothed washers on the secondary gearshaft as spacers. They distorted the bearing seal enough that it fell off!
I removed the bearing and reversed it for the good seal and made a proper spacer with 10mm ID and 13mm od.
This box does have it's own 2 bearings for clutch bell support though.
What is the prognosis for longivity for the chain if I run oil in this box?
