birdmannn101
Tried to search "best headlight" but couldn't search with both words so I am asking the group which headlight is the best, brightest and will last a little while on the batteries?
Cree, even DIY. I use two cree LED's taken from head band flash lights. I connect them directly to my sturmey archer generator hub. THe hub is ac so they flicker under 5 mph. A cree can handle the generator AC without a resistor. Thousands of miles on mine. I run the cree's off one AC phase and running lamps on the other AC phase.
What is best depends a lot on where you predominantly ride. If you're on well lit streets you won't need as bright of a light as streets with no lighting. So consider where do you ride at night. I live in a small town where all the streets are lit up at night.
Jerry, My main concern is being seen during the day. Been there and done that when some one pulls out in front of me because they are on a cellphone with blackened side windows or see me as just a bicycle rider, capable of stopping on a dime.
