jeffreykogan Member Nov 28, 2021 #1 Hi, I have a 79cc predator (which is a 4 stroke) and I was wondering if having a bit of backpressure from a muffler would make it run better. I currently have it straight piped, should I switch it out for a different exhaust?
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Nov 28, 2021 #2 A little back pressure is good for low end power; but having less back pressure helps the top end power. I prefer less back pressure on all my 4-strokes... You can really help the low end power by actually pedaling the bike at low speed. Another thing to consider is that when you add a straight pipe (& or a better air filter), you will also need to increase the jet size!
Z zean Active Member Nov 28, 2021 #3 ...and you don't have to pedal very hard to get a noticeable difference in low end power.
