deacon
minor bike philosopher
Okay I have finally tested my DIY friction drive and come to the conclusion it just won't do. I think it is a manufacturing flaw but it just doesn't have either the speed or the torque needed. It should have more speed than it does but it just doesn't.
So I do have an 8" scooter wheel coming that will be a twin to the one I run now on a 350 motor with more or less satisfactory results. It is slow but has a lot of torque which is really more important to me.
I also have an 18tooth sprocket for the motor on the way. It should be here tomorrow. That should help the speed a little. I also thinking I might go with a direct power and flush the controller.
I took it off last night but couldn't do a test I burned up a 15amp switch. I think I am going to get a 40a relay like one of the other members is using. It sounds like a good idea and would give me more amps for the torque I think. It seems the controller limits the available amps where as the switch allows to motor to draw all it will draw.
I know it's not good for the motor but the are pretty cheap and I don't know how long one will run.
