Tim_B_172
Here's my situation: I'm using that V brake adapter from here with an HD rear wheel from Spooky Tooth, and thisdual pull brake handle with a set of promax V brakes that came on a Schwinn Searcher. It seems like I can't get the brakes adjusted right, they either drag the rim pretty hard or they don't give enough stopping power. Could it be that these brakes aren't that great? or could it be that this brake handle isn't made for V brakes?
It should be noted that I use the same brake handle and brakes on my other bike and it stops just fine.
If these brakes are crap, then could you recommend some good ones that won't cost hundreds of dollars?
