G'day R/birds, hope all goes well with the build. I strongly recommend disk brakes, welding mounts is no harder than posts & theyre much safer. I had front disk only but have now fitted disk rear wheel. I need to weld the mount also, as well as attach points for tank, motorcycle led indicators & the x chamber once tuned. I'll run motor in first. I need to replace the rear wheel gear/freewheel cassette. Its been dicey for ages but it didnt matter with the stock setup. Since fitting the shift kit it has started to fail so no riding for the past week. Ratios are 13 to 29, 7 speed. The new rear wheel is an 8 speed, I used a spacer to fit the 7 speed cassette but will fit an 11 to 28 8 speed cassette this friday. Keep you informed. Cheers mate
