Anyone mounted motor on this bike?
toker_ace
schwinn link----$169.00 walmart. Wondering if a regular kit will work on this bike or will I need the new slant?
I dont see why it wouldnt work, only problem I can think of is when installing/removing the spark plug because of the tight fit. You could work around that by filing down the plastic bit at ignition terminal so it can clear the top tube and come off the plug. I did that once and it worked a treat. Also, you might need to modify the spark plug remover by cutting it in half.
