Aluminum Sprocket
How well will a Aluminum Sprocket last on a 2 cycle ? it uses a #415 Chain. usflg
Thanks for any anser
My Atomic BB has a MM hub adapter, 40t alloy sprocket, and KMC 415 chain, that I bought from Pirate cycle a couple years ago. It has about two thousand miles on it. The teeth on the sprocket are in, not good condition, great frickin condition. The chain itself has streached out over the years, and I removed one more link last year. The chain is probably more worn out than the sprocket. I maintenance the chain often, and I always use a good brand of chain lube.
This is how I ride it.
http://www.youtube.com/watch?v=9rtBSJVl5O8
Maintenance is key with aluminum sprockets. If you're a lazy procrastinator like me when it comes to maintenance, stick with a steel sprocket.
