yea thats the motor but srry i only deal with pirate cycles lol the extra money is worth it for customer service anydayyyy
FLYBYTACO,man if I only new the jet ingines had a larger mount I would have bought them.....Now Im going to have to make a U clamp mount.....Oh well I have the engines now so I have to deal with it.....
the racing carb for 70 bucks is a good deal just for the off idle to quarter throttle tuneability i have 2 of them other than that pretty good performer as the nt carb that comes with the kits there all good well never had bad exp... and good lookin on the pirates deal justins the man. he has all the goodies 4 sale 33 tooth sprockets on the way
I asked falldownstand up about the intake on the bikes pictured earlier (like the red one) but I messed up because Flyby taco did the original posting- so I went looking at intakes, and the one on those bikes seems to be the alloy ported billet from Pirate Cycles (I just got mine), who also have the carbs.
I haven't installed it yet- has anybody got any comment of the performance of these things?
There are these two other carbs- the racing carbs pictured- kinda pricey- and a newer chinese carb to start shipping with kits (half as much) that claims wider ports and bigger jet. (on spookytooth) I guess it's too new for anyone to actually have compared the two, but who has any experience with either?
Hi Nashville,
The other carb you speak of is the one that comes on the grubee skyhawk kits. We stock it also. It has a fuel on and off on the carb itself and it is as good as the other carbs. Not better. I will be listing that one as well. We have been getting some calls on it.
The race carb has a air and fuel screw for a leaner and richer fuel adjustment. It also comes with a Thumb choke lever (very convenient). It is a larger more quality carb with tun-ability. It will not help if you are running the Gen 1 black cat muffler as that muffler is to restrictive to release sufficient airflow.. Otherwise its great.
The intake is another good power mod for the money! When installing, Be sure to pull up your clutch cable eye bolt and cut off a 1/4 inch of thread. Then replace. This allows you to re attach your carb and not hit the barrel of it on the bolt itself. Its a easy job.
Hope this was helpful to you.
exactley what i think. the billet intake gen 3 muff and racing carby are the best bolt on power avail. no need for carving up your jugs trying to shadetree port and ending up slower... learned it the hard way.. anyways theres alot of steel and aluminum in theese little motors lol
I've been boring out the billet intake more- I guess the idea for perfomance is that it's shorter, but when I stuck my little finger into it, and then the stock long intake, the stock was actually wider-
NOT NOW!- a drill bit and some filing and the alloy comes away pretty easily- the billet is now gonna be wider open than the stock intake, and much shorter. But upon inspection of the whole deal, the determining factor is still the port diameter of the carb, and I see that i can get maybe 2mm more opening there if I ream it- but I'll have to take it all apart to not get shavings in the motor or carb- and I'm busy with other things. Yeah modifying the cable holder is another thing too- luckily I have a hacksaw.
I think I'll go with the newer NTS myself and save some money- they are claiming ports that are 3mm larger, and it has a larger jet. I've thought from the beginning that the carb has always been the weak link.
