Air Filter Size Measurement.
Toadmund
*Frangle Inside Diameter : 60 mm
Want a bigger air filter, for bigger air
So this frangle, what's the angle? Is this the diameter of the inside of the rubber lip of the air filter mount, and the OD of the air filter mount on the carb?
So, If I want a filter for my RT carburetor and the diameter where the rubber lip of the air filter fits onto is 60mm.
Is this then the size of the air filter I want? Just need to be sure if I order this.
Any opinions on the wisdom of using an filter like this?
Thanx.
Nobody can answer this?
I believe this air filter will fit, am I right?
Aboved motorcycle models are for reference only, please measure your carburetor's mouth OD in order to get correct measurement.
I guess so then.
Good choice of air filter then?
