adjusting the air fuel mixture on 49 cc
mapbike
5,502
109
Central Area of Texas
The stock skyhawk 49cc carb
do a search for carb tuning, if you have the stock NT type carb there is no screw for changing mixture, it only has an idle adjustment screw, if you have the newer CNS carb I have read on here that there is a brass plug you can drill out and get to the air adjuster screw for better fine tuning of the mix.
adjusting the clip on the throttle slide metering needle is the way to fine tune the low to mid range fuel/air mix, changing size of carbs main jet is how you make the final tune for overall best performance with the carbs.
do some searches and lots of reading and you will get a good idea of what you need to do to get you carb set up right.
best wishes, Map
