Hi,Gang.Here's Pics of my latest version of what I think a clutch arm should look like!,and how it should function!
The clutch arm itself is longer than the stock arm which give you better leverage which means easier pull!
It is adjustable which means you can dial in the alignment with the cable stud on the motor.NO-RUB=NO-wear!
The cable bolt rides in a bearing which means your cable will stay aligned throughout the engage-dis-engage cycle!
The cable bolt is adjustable which means you don't need to monkey with the brass cable holder to tweak the adjustment!
This is my first proto-type!
I'll start making them and selling them if I can generate enough interest!
Your thoughts? Kip.
[email protected]
Your thoughts? Kip.
[email protected]
