deacon
minor bike philosopher
Yesterday I had a wake up call. The hub motor ran out of the front forks. Fortunately I was in the drive and testing the throttle on the trike so I stayed with the trike. I cursed then removed all the parts of the Hub motor.
Since I had been using it in conjunction with a Friction Drive (FD) motor I decided to just use the FD and see what happens. So I spent twenty minutes putting the 24" front dumb wheel back on the trike. It was the wheel that came with it.
Then I messed with the FD motor trying to get it straight, but nothing seemed to work. So I decided it was time I rebuilt the frame using all bolt together brand new metal.
Since I had to buy metal anyway, I went with alum angle side rails to hold the motor and wheel. Removed the hinge I had been using, then made a bolt on solid connection to the trike. Let the weight of the motor be the only tension and it seemed to work fine at the test ride.
Since I jacked up the voltage of the motor system it has about 800 watts at 36volts. That is the official amount on the controller. I may just jack it up again to 48volts then again maybe not.
I realized the trike performs better without the heavy hub motor. I know that goes against all our thinking, but I swear it does. For one thing the trike is much lighter in the front with just the FD motor.
Now for some things I discovered on that test ride.
1. I need to change my thinking back to what it was in the early days. ITS A TRIKE NOT A MOTORCYCLE. I don't have to run with the big boys. It will pull very satisfactorily on level ground and on most inclines. When it gets steep, I pedal as if I was on level ground and it go right up in most cases.
2. I get a little exercise, which is what I had forgotten as I grew fat and lazy.
3. I love friction drive bikes and now trikes. It's the simplicity stupid. I know hub motors are simple as well. They either run or they don't but they are heavy, expensive, and don't fit the front forks well.
So I have a new attitude and an new motor sort of. The sun is out so I'll add some picture now.
