young grease monkey
i'v had my engine apart for a while now and was turning the flywheel and looking at the cam timing. i noticed that halfway in the compression stroke, the exhaust opens about 1.5mm. this is to make it easy to turn over i think, but will hurt lower end power. i found the culprit!
it has a centrifugal activator that disengages it. it may help idle if i remove this because it will help low rpm power
