who makes a mount for a custom build....YOU DO
what you think they make mounts to fit every motor to every bicycle ever built
the 99cc pred motor was never intended to be bolted into the frame of a bicycle that is the fact. There are non kit builds and are called just that because you may have to modify or make parts or use parts that were never intended to be used the way you will need to use them. That is where some get the most enjoyment from this hobby. You have to be willing to look at the problem and see what you can do to fix it.
Ok I'm gonna try this again. I understand everything you are saying, it's obvious. I get it that you think everything for a custom build should be made by the builder. I get it that parts will need to be made or modified. It is obvious. My question was (for the third time) is if there a mount that can be purchased that can acomplish the offsetting required of the cvt. If not, I will make one.
THANK YOU Wayne!
You answered my question perfectly, and didn't make me feel like a fool either.
