Edenfrench57
My 80cc is losing power at top speed and feels like it’s bogging down and isn’t holding speed please help
			Welcome to the forum, it can be a number of things that cause the engine to lose power. One easy test is to remove the air cleaner and do a run, if it runs better you need a smaller jet, if it runs worse you need a larger jet. At what speed and rpm is it topping out? The ignition doesn't have a advance so it limits timing.
Will it increase speed if you back off the throttle some? Wide open throttle is regulated by the main jet, when you get a chance try the tests to see what helps. On a new engine your speed is not bad, after break in it should get better. Oil to gas ratio can hurt performance too, I run 24/1 for break in then after a couple of tanks I switch to 32/1.
Like I said try 3/4 throttle and see how it runs, how much have you run it? If it's new I would ride it till it's broken in.
You need a smaller jet or to open up the exhaust, reducing the back pressure on the muffler will help too, a two cycle relies on muffler back pressure to perform. It's a balancing act that takes awhile to get right.
