Z zean Active Member Dec 5, 2010 321 216 43 california Dec 7, 2018 #1 Say, the 79cc predator, the transmission that comes with the monster 80 kit, can that be fitted to a 212cc predator? Thank you.
C curtisfox Well-Known Member Dec 29, 2008 6,048 3,960 113 minesota Dec 7, 2018 #2 Think you should check the bolt pattern difference between, it has also been said the mounting plate that come in kits has cracked. It may just do that on the 212.............Curt PS the shaft size is 3/4" on 212 so clutch would have to be changed. Reactions: Tom from Rubicon
