thingswithwelding
Hello. Im getting to the point where my build is engine related. Im finishing up,framework. I need to make a manifold as my engine is tilted 25 degrees forward. I read and was told to change out my carburetor for a PZ 19 or PZ 20.
Questions.
1. Are all these PZ Carburetors the same? Is there anything to stay away from on ebay etc?
2. Im feeling that I may need to fabricate my manifold myself because my build is custom with the 25 degree tilt. So, I dont think there is going to be a manifold that will make my carb level like it should be. >>>Question>>> Can the manifold have seems on the inside where the welding on the outside would be? Because Im going to have to make a bend and seem to get the right angles you see? Can I put welds near the ends of the manifold tube and just Jb weld a smooth surface on the inside? Anyways, Id like some tips on this manifold thing as I want to run into no problems. I know JB weld fuel resistant kind isnt the best way to do anything, I just figure a weld seem will cause fuel delivery problems.
3. Am I missing something? Does the carb need be exactly paralell flat to the ground?
Thanks guys. Thingswithwelding.
			Questions.
