'79 Puch Maxi
talontsi1225
Hello all I'm new on here and have searched around the internet but haven't found much so I figured I'd ask you guys. Okay so I've got a 1979 Bmw Puch maxi 2 hp moped that has pedals to pedal start it. Well I've been wondering if there is a way you could wire up a ignition switch in? I know you could technically just pick it up and steal it but it'd be easier to just pedal start it and off they go! Maybe I'm paranoid too but I guess just wondering. Any suggestions welcomed! Thanks!
Big locks and a hidden kill switch is a good start. The hidden switch means the thief will be pedaling themselves to exhaustion and won't get far.
Ah the hidden kill switch would work. Just something simple like a toggle switch would work right? But with being a pedal start there really isn't wires to splice into before the motor add one in, its just that cable.
Connect toggle switch to ignition and ground. If not, the thief can simply run a wire from battery to any ignition point. With the toggle connected to ground, the bike won 't jump start.
