66cc high compression race engine wheel lock up
rowenj
28
Whenever i pedal start the engine the rear wheel always locks up for a sec and drags the tire
Also have broken spokes and fuel starvation issue
crassius
4,032
158
USA
for the starting part, I'd say to use more pedaling and less clutch - ease it in slowly while pedaling harder
  • Like
Reactions: rowenj
Arturo Garza III
19
You should adjust the clutch wire.
To adjust the clutch wire. Unscrew the small screw near the end of the clutch wire. And push the silver metal in small intervals , until the problem is fixed. Or you could adjust the wheel location , to more near the end ; near the motor.
crassius
4,032
158
USA
yeah, opposite of how a car works - there, you rev motor to get power while engaging clutch - here you push harder with legs while engaging clutch
