greenrider
Hi guys, I'm hoping y'all can help me out.
I've got an (alleged) 53cc 144f 4 stroke clone ala Amazon.
Once I did horrible things to the motor mount to get it on the huffy bayside it started right up and runs great . . . .except, after it gets warmed up about a mile or so down the road and the drive stops fully disengaging properly and starts squawking a bit, which I can sometimes stop by give it more throttle, at least temporarily.
Now it has a centrifugal clutch, a belt drive transmission, and a bronze bushing inside the bell.
Now I read somewhere else on here as how that could be the bushing instead of the clutch. So I've had that bushing off several times and the bushings was pretty scored up the first time I took it off, enough to catch my thumbnail, at first, pretty much down its length.
This appears, to my inexperienced eyes, to be a plain bronze bushing. (I have a sintered oil impregnated bushing on order)
I tried to polish away as much of the scoring as I could using a dishpan pot scrubber, and got a lot of it. I of course took a clean shop rag and cleaned inside the bell where the bushing sits.
I've since lubricated it, 1st - with grease (which I may have messed up by using marine grease as I had no high temp grease on hand) and when I rolled the bike out to start it, it rolled easy without trying to engage. I then rode it a mile or two, with the clutch and transmission working perfect until the engine had been hot for a while and it stopped disengaging completely and eventually started squawking like it wanted to seize or something.
I then took out the bearing again, cleaned, lubed with machine oil. Same result as with grease, starts out pedaling or walking it with no engagement, then a mile or two - same thing.
Today I said what the heck (I didn't really say heck
) and when I finished cleaning lubed it with some wd-40. Same result.
The fact that after I clean it up it stops engaging, so the back wheel ain't so hard to turn, and runs fine for a mile or two before messing up, then is fine again after I clean up the bushing, makes me think its the bushing that's the problem.
Any of y'all had this same problem?
Any info and/or advice is appreciated.
