hmiwb
I finally got my 4 stroke build put together and took it for a shakedown ride. The first 2 mile cruise went fine with a few minor adjustments along the way. By the end of the second loop I found that the clutch would no longer release at idle. The engine died at every stop. I've heard of this problem before but I'd hoped that by now it would be solved. What is the best solution? I don't want to spend $40 to buy the 3 springs I've read about. Does adding washers under the clutch springs actually solve the problem? If so, how many or how thick? As an alternative I have a new clutch for the hoot transmission. Would the insides of that clutch work or is their clutch as bad as their transmission? Thanks guys!
