4 stroking at low speed
Discussion in 'Motorized Bicycle General Discussion' started by porter1, Sep 11, 2014.
  1. porter1
    porter1 New Member
    Sep 3, 2014
    8
    I am a newbee, here is my problem. china girl 80cc wants to 4 stoke until 12 mph, the is no adj. on carb except idle speed. I don"t know what carb. I have all it says on is" speed". I have maybe 50 miles on the motor. I started to run 40x1 mix with Yamaha oil. is this normal or will it get better when it gets fully broke in? I know someone here can help. thanks.cvlt1
  2. Henshooter
    Henshooter New Member
    Feb 10, 2014
    275
    The standard jets on the factory carbys are way to big IMHO usually .68 ,my suggestion is to go down to a .65 and see if that helps
    But we really need more info such as jet size the oil your running and the type of carby ( I suspect the NT )
    There can be only two main suspects in my oppinion and they are jet size and fuel mix .
    Being a newbie you can get somewhat daunted by the carby adjust but it's simple ,I always run in my motors at 25:1 and general running after breakin at 32:1 ,you should find if you are running the kit recommended mix ,swapping down to 25:1 should somewhat fix your four stroking issue ,40:1 for breakin is IMHO way way to low to be any good for the motor
    Try these and get back to us with your results
    Regards Hen
    #2 Henshooter, Sep 11, 2014
  3. porter1
    porter1 New Member
    Sep 3, 2014
    8
    was running 25x1, was worse, the guy I bought it from said go to 40x1 now he already ran 1 tank of gas through it, I have ran 1 also, where do I get jets?
  4. SpecializedMountainMoto
    May 28, 2014
    194
    Wait until u get at least 100 miles on it before u start messing with it, but I would go with a 24:1 mix until 100 miles
  5. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,466
    42
    300miles would be better before trying to tune it - the older speed carbs were about 2mm larger in the venturi than NT - didn't make them horrible on the standard engine setup, but they worked better with an expansion pipe - I currently see a newer ver of the speed carb being sold now, but don't know what has changed
  6. porter1
    porter1 New Member
    Sep 3, 2014
    8
    ok, went with 32x1 mix, as the miles are going up the 4 stroking is getting better, also put in the proper heat range plug. It"s getting better every day, so I think I'm good to go. I must say though my Honda and Yamaha mopeds ran much smoother. those **** are hard to beat.
  7. crassius
    Sep 30, 2012
    3,466
    42
    Yeah, if price were king, these would be in the royal family.
