twowheeledfox
Only three weeks after building my 2 smoke rat bike, a new build idea is being formed... 4 strokes!
Now the advantages of the 4 stroke are obvious- won't go into the disadvantages- but mainly less vibration, oil only required every 50 or 100 hours of running rather than every fill-up, and a nicer sound.
So, some basic questions about the in-frame 4 stroke:
There appears to be three main things: The motor itself, the mount, and the clutch/tank/controls.
I would like to use something like an HF motor. My requirements are a comfy 30mph, in-frame, and not with a shifter kit (can't afford it while buying a frame and lights along with the motor). I do not want, nor could I use, a tiny 35cc or 50cc motor (unless they can somehow do that speed comfortabley, which I doubt).
How could I mount such a motor in-frame? I cannot use a welder, heavy-duty grinder or any other high-grade equipment. I have a drill and high-quality bits, but other than that the extent of my metalworking ability is a hammer.
Than there is the controls- how many controls from the stock two-stroke such as the throttle etc can be used or easily adapted to an industrial four-stroke like the HF? I can't modify the carb for the throttle cable, for example. Thankfully instrumentation, mirrors and lights are seperate systems on these bikes or it would be a nightmare.
Finally, final drive. Chain or belt? Singlespeed, two-speed or cvt? Manual or centrifugal clutch? What sprocket sizes would be appropriate?
Thanks all.
Thanks all.
