36 tooth sprocket need!
some bmx bikes front sprocket can be modified for a rear sprocket . you will need to drill mounting holes and maybe rework the center hole as long as the engines chain will fit the sprocket you find it should work fine. some front sprockets or even rear bicycle sprocket can be made to work.
You might not find a 36 tooth but a 38 tooth etc but not as expensive for testing to find something close.
There is vendors on the forum side bars who will sell you just what you want if you want to do some looking.
