i have no manual to hook up. it has only fuel line from gas tank to carb attached .need configuration to other brass connection.thanks.
Dont have a clue to what your asking here.
Are you needing to know how to put carb on engines intake manifold?
What engine do you have ?
What brass connection are you asking about? Only one needed to be concerned with is the one for fuel line.
If you have a Grubee Skyhawk engine then you likely have the CNS carb there are several connctions for hoses but those are just vents and dont need to be connected to anything just let the hosehang where they will. I dont use the CNS carbs myself but I think im correct on what I just told you about the e tra stuff on them.
Just not enough info in your description for anyone to know for sure what you're asking.
Map
