212cc Predator Schwinn Sierra Enduro Build
ultralight01
337
Hood River, Oregon
It's time to get building.
THE BIKE
90's Schwinn Sierra. Will be upgrading fork, handlebars, brakes and wheels. New paint and fenders will be added.
The ENGINE
Predator 212 Hemi. IF I can get the c clip off the governor shaft. That is truly a pain in the but. As you can see it's currently in pieces for governor removal, low oil sensor removal, and some mods.
THE PARTS
Seat, plastics and gas tank from a crf50: http://pages.ebay.com/link/?nav=item.view&alt=web&id=262483805951&globalID=EBAY-US
Jackshaft pieces: IMG_3519.JPG
This suspension fork: http://pages.ebay.com/link/?nav=item.view&alt=web&id=262483805951&globalID=EBAY-US
And more! Predator will have a new exhaust and air intake. 35 chain will be on the jackshaft and 420 to the back wheel.
ultralight01
337
Hood River, Oregon
Well I was sure the212 would fit. But without cutting off the gas tank mounts, it won't. So I'm going with a 79 for this bike and I'll use the 212 on my next.
MEASURE TWICE
2,555
791
CA
There is a section of threads called:
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Dremel or a Die Grinder with cut off disc makes short work of unwanted parts. But I don't have that much experience with the HF engines and if a smaller one will work, it probably is best. The 212 is big but a 79 is 3hp anyway. 3hp 4 stroke with low end torque and a bit lighter weight would be good!
I been using Briggs 3 and 3.5 hp and I fit it but at around 15 degree angle. I heard that is the limit for lubrication to function well. But when I am off road riding up hill and think combined I over do it for a while. I made an adapter so on level ground the carb bowl is level even though the engine is on a 15 degree angle tilt.
Agreen
792
11
Southeastern GA
The 212 is a monster on bicycles. It will turn your teeny spokes in to pretzels. It also REQUIRES disc brakes! It will pull wheelies, especially when you don't want it to. Mine ran 4 feet up a tree when I started it and the carb slide was stuck wide open. They can also propel your butt to 60mph easily, which is kind of scary on a bicycle (and I ride much faster than that daily on a motorcycle ) Bicycles just shouldn't go that fast.
Good idea with the 79cc engine. I will probably be getting one to replace the Honda engine on mine (the exact engine that predator cloned as a 212)
ultralight01
337
Hood River, Oregon
Yeah... I think the 79 will be good oh this one. I'll make some kind of monster bike to put the predator on.
MEASURE TWICE
2,555
791
CA
I saw a guy using the 212 which I think is 6.5 hp on a skate board. Needless to say when I was asking to see him ride it, he was saying to me and his friend that it hurt his feet and thought it was too much. I was thinking the throttle should be able to start away easy, but maybe the clutch grabs to fast? In any case skate board 6.5 hp did sound insane.
But really a 2hp Briggs I had fixed a stuck valve and from the trash it rode nice even without a clutch. The pulley to wheel attached with wood and bolts as a kid, I rode it everywhere.
Tony01
1,412
890
sf bay area
You don't need those gas tank mounts anyway, in fact I think they are a liability and should be cut off. If you hit the motor on one it will take a bite out of the crankcase. My buddy removed both, I'm removing one (flywheel side) next time I take out the motor, possibly both if I can mount the front different. My buddy uses the cylinder mount with a heim link as the front mount.
curtisfox
5,420
2,145
minesota
Back in the 50's i put a 1 1/2 Briggs in a old bike, with V-plex clutch ( no longer made ) belt primary. It went 25 mph all day long, being a kid took it down and opened up the ports with rotary file and drill, got it to go 35 mph. Was really fun, then being 16 traded it for Model A Ford....................Curt
