deacon
minor bike philosopher
As most of you old timers know I build with 20" rear wheels.  What I usually do is convert the rear wheel of a 26 or 24" bike to a coaster 20" wheel.  I like that low rear end so that I can get my big one over it easily.
I have been thinking about another problem I have with bikes. Moving them around the shop. I have a 24 " full suspension that I converted to a 26" front wheel and a 20" rear wheel and that goes in and out pretty good.
I have a 27" three speed that I converted to a 26" front and a 20" rear wheel and it goes in and out of the shop pretty well. The frame is actually pretty short front to back.
My third bike is a 26" frame Huffy good vibrations bike. It has a full sized frame. It is a mutha to get around the door that some idiot hung to swing in the wrong direction. Then some other idiot (me) put in a raised floor that limited it to only half open. That second idiot also built a partition to make a seperate storage area. anyway there is a tight 90 degree turn going out. The full sized huffy has to be hossed out. I am getting old and the hoss factor is decreasing quickly. That being the case the shorter bikes are much easier to move around.
Enter the 20" hybrid bike. I usually buy two bikes anyway before it is over. I have to have the pedals and chain ring from a 20" when I install a 20" rear wheel. My legs are to stiff to pedal a 26" pedal set. So the easiest would be to take a 20" and just change out the front end. It should give me the same thing i have in the others only in a short bike.
So I'm going to measure the huffy connection and try to find a kids 20" bike with the same size connection. Anybody ever do this kind of thing. I could use some input on whether the connectors at the fork are the same or not.
Let me know or I'll keep you posted on the results.
