motoringbike
Greetings!
I need a 415H chain KMC (1/2"x3/16") for the rear wheel that bolts onto the spokes sprocket.
Bicycle stores sell them, most (if not all) have to order them in.
Local Bicycle Store has to order in 98 links K415H for $18, one on Amazon has 140 links 415H $45 and its Prime Day. But yeah I will just order from LBS.
Problem - Do I order two because I have a Townie 7D feet forward. Havent counted the single speed links yet. I need to know the pin to pin length of the 415H chain, is it 1/2"?
Is the 3/16 the pin length?
Then calculate or figure out how that compares to my KMC single speed chain. I'd count the single speed chain links required for my application, measure the total length with a tape measure, then divide by the 415H pin to pin length.
Basically I have the right length single speed chain from my motor to the 41T bolt on spoke cog. But that spoke cog requires a 415H chain. The good thing with the bolt on cog I bought was there is spoke mount holes, for the adapter, but there is also the IS disc bolt hole pattern which is good for my needs.
Next question is, what is the smallest bolt on spoke cog there is?
Next question is, can I adapt a crank set gear to fit the adapter, or does the crank set gear whether it be 22,24 on up to 44,48,52. What I am thinking is there would need to be fabrication because the crank gear is too open. But thinking about it now, I can just lay the crank gear over the 41T cog and see where the bolt holes lineup.
https://www.lfgss.com/conversations/149932/
Quote
Modern bicycles use roller chain to connect the cranks to the rear wheel. Chain drives are among the most efficient means of power transmission known. Chain size is specified by pitch and width. The pitch is the distance between rollers (1/2" on all modern bicycle chain). The width is the internal width where the sprocket teeth fit in. Bicycle chain comes in two basic widths:
You will come to learn that Sheldon Brown was your friend http://www.sheldonbrown.com/
END QUOTE
Quote
- 1/8" chain is used on most single-speed bicycles, and bicycles with internal gearing.
- 3/32" chain is used on derailer equipped bicycles that have more than 3 speeds.
END QUOTE
