Agreen
Before I throw this weedeater leaf blower is hard as I can in to a lake. With bricks tied to it.
A little history:
-I found it sitting in a pile of crap by a trash can.
-It has good compression.
-I rebuilt the carburetor, and it's definitely working (fuel sprays out soooo nicely without the spark plug in)
-I have resealed the crankcase
-I seem to have intermittent spark.
If I pull the spark plug and put a finger over the hole, it pushes my finger away and shoots fuel mist, every revolution. It has NOT ONCE even coughed or chugged. I pulled the carb (zama/walbro diaphragm carb) and cleaned it. And I do mean CLEANED it right! I completely disassembled it, soaked the metal parts in carb dip over night, and i even pulled the high and low needles out and shot carb cleaner through them to see that the main jet and idle orifices weren't blocked. The crank case leaked, and I fixed the leak. The primer works great, it has a new filter stone and fuel lines. Now it's carburetting, but not firing at all!
I tested spark with a tester, and got good spark. Later I did the same test and got no spark. I fooled with the settings some more, nothing. I tested spark by grounding the plug and got good blue sparks. Did some more work, then I get a few random sparks every few rotations. I have other (similar) 2 strrokes sitting in my garage, so I tried replacing the CDI with another one. Same spark story, and still no start. The magnets... well, I don't think the magnets can lose their magnetism. The flywheel can not be keyed any other way (there's a flat side, and the fins go out). I also set the air gap for the magneto with 3 sheets of notebook paper as recommended. Nothing. It's a good plug, I've tried 3 different plugs, another CDI, and the carb works, and it has compression (and crankcase pulse to the carb's diaphragm, which would keep it running, not prevent it from starting)
Should i drop the $30 on a new CDI for a gamble? I don't want to keep pouring money in to something that's not worth it. I have an electric leaf blower, i just thought a gas one would be nice to not have to drag my extension cord around.
Thoughts?
A little history:
Thoughts?
