Will this work for job.......
Thanks
http://www.woodcraft.com/Product/2000784/20/Drill-Set-Wire-Gauge-Size-20-Pieces.aspx
Thanks
Toothy;560991How do you solder the jet? Just get it hot with a torch and touch the solder to the hole?[/QUOTE said:Yep, what I do is hold it with a needle nose vice grip & hover it right at the edge of the blue flame of a benzine bottle torch(the kind used for sweating pipe), 2 or 3 seconds is enough as brass is an excellent conductor of heat, then just lightly brush the solder to the hole. Make sure you use flux core solder or it may not stick, & not too much either, because the more you use will mean that much more you have to drill out.
Toothy,
You don't need as much heat as a gas torch will provide. I use an electric soldering gun.
You should use solid core solder, not flux core, and I've always had good luck with either 60/40 or 50/50 solder. I like Nokorode paste flux.
The jet MUST be clean and oil free. I like to sand them a little with a 3M pad making sure to get any surface oxidation off leaving clean shiny brass around the orifice.
A pin vice is almost an essential tool for drill bits the size we're talking about. Don't try an electric drill. Run the bit by hand only.
EDIT: Sorry SuperDave. We were typing at the same time and gave the guy conflicting information. Just another example of "use what works for you"![]()
Toothy,
being a fellow redneck i have to agree with the stove top method... Just don't let the wife catch ya... Lol...
I remember my wife not too happy with me throwing parts in the oven to cure the high heat paint or powder coating... I tried to explain the parts were too big for the toaster oven but i don't think she fully understood...
Seriously, the stove top method will work just fine and the wife should be ok with it too...
Unless you apply too much solder and it runs down onto the heating element or the flame ring. Then you'll have some explaining to do.
