The Schwinn Riverside with 79cc predator
BelayBoy
the fun continues
got my 79CC predator kit together
total $776
0. $99 - 79cc predator engine
1. $25 - Motor Plate
2. $30 - V-Frame Mounting Plate Kit
3. $30 - Wide Crank Conversion Kit
4. $30 - Wide Crank Pedal Kit
5. $40 - Max Torque Clutch
6. $20 - 5/8" jack Shaft X 12" WITH 3/16" KEYWAY
7. $60 - Shift Kit Conversion Assembly - jack shaft mount
$40 - drive sprockets
8. $17 - dual brake lever w brake wire
9. $31 - disc brake w mount db-2
10. $16 - uni clamp on breather filter 3/8" hose
11. $27 - throttle and throttle cable
12. $30 - new steel rear wheel
13. $75 - Sprocket Adapter (Clams Shell Small- CSS)
14. $15 - 44 Tooth Rear 9 Hole Sprocket
15. $16 - the chain #35 Chain
16. $16 - the chain #41 Chain
17. $60 - GAS TANK leaked so i returned it
18. $70 - lights, blinkers, brake light, 4 computer 3 wire cables, switches, connectors
19. $10 - bolts for the engine
20. $20 - home made muffler
pc of advice, think twice before you try to build anything custom and then think again
this is something you should keep in mind before starting this project
Build your own bicycle.
The frame and parts to complete the bicycle as bicycle will run you more then $350 (wheels, forks, stem, handlebars, brakes, frame, seat, seat-post, the fenders) make sure you get bike frame with 1 1/8" fork
here is something i wish someone did earlier, complete set of parts for 79cc predator including trial and error
1. 2306 Motor Plate for 79cc &99cc HF Engines $25.00 not including shipping
https://www.affordablegokarts.com/m...ode=A&Product_Code=2306&Category_Code=MTRBK79 plate mounts to your frame not included you will need to see line # 5. this is a must
2. 2404 Max Torque Clutch, High Stall $39.00 not including shipping
https://www.affordablegokarts.com/mm...gory_Code=99cc this is a must
3. 1pc to 3pc Wide Crank Conversion Kit $18.99 not including shipping
http://www.bicycle-engines.com/1pc-t...rsion-Kit.html this is a must
4. 3pc Wide Crank Pedal Kit $29.99 not including shipping
http://www.bicycle-engines.com/3pc-W...-3pcCRANK.html this is a must
5. Black V-Frame Mounting Plate Kit $29.99 not including shipping
http://www.bicycle-engines.com this is a must
6. 35B22 Sprocket 35BS22, 22 Tooth Sprocket #35 Chain $14.57 including shipping
http://www.usabearingsandbelts.com/m...ler-chain.html
7. (2) 5/8" UCP202-10 Quality self-align UCP202 $14.66 including shipping
http://www.ebay.com/itm/2-5-8-UCP202...item1e74b08f16
8. ROT480 5/8" O.D. SHAFT X 12" WITH 3/16" KEYWAY FULL LENGHT JACKSHAFT MINI-BIKE
http://www.ebay.com/itm/ROT480-5-8-...733?pt=LH_DefaultDomain_0&hash=item4ac7559975 $20 this is a must you can get it from sick bike parts
9. http://www.mcmaster.com/#roller-chain-sprockets/=mmv1x8
10TOOTH 5/8"ID 1.84" 7/8" 1 1/4" 6280K482
#41 Chain $10.36
10. 80cc motorized bike gas engine bicycle - dual brake lever w brake wire
e-bay seller boygofast (25739) $16.30 this is a must
11. 80cc motorized bike gas engine parts - disc brake w mount db-2
e-bay seller boygofast (25739) $31.00 get it if you are creative
12. laid back bicycle seat post w/support steel 25.4mm bmx cruiser lowrider fixie
e-bay seller cruisinthelowlife (8949) $14.98 ( do not recommend this )
13. uni clamp on breather filter 3/8" hose up102 - free usa shipping
e-bay seller cycle-celler (13314) $15.77 this is a must
14. throttle and throttle cable
100" throttle cable & 7/8" deluxe twist grips mini bike minibike chipper part
e-bay seller allseasonspartsplus (18405) $26.95 ( do not recommend this, you can purchase better on ebay)
15. kill stop push button switch go kart mini bike minibike
e-bay seller allseasonspartsplus (18405) $6.95 build you own don't purchase
16. (optional) CB RADIO ANTENNA INTERNATIONAL BRACKETS S0239 STUD MIRROR MOUNT 53709 ~NEW~ 1 1/4 you will need 2 each $10http://www.ebay.com/itm/CB-RADIO-ANTENNA-INTERNATIONAL-BRACKETS-S0239-STUD-MIRROR-MOUNT-53709-NEW-/230990291643?pt=US_Radio_Comm_Device_Mounts&hash=item35c81822bbWHATEVER
17. rear wheel from http://www.huskybicycles.com/mm5/mer...t_Code=500-232 $30 this is a must
18. Big Earl 1-1/8" Black Stem 50mm +10° 31.8mm Bar Clamp "ebay" for mountain bike forks
Expedited Shipping : FREE $20.00 (experimenting)
20.
a.) paid total $91.89 (JackPlate $69.95, Bearings $6.95, 4 mounting bolts)
http://www.hotrodminibike.com/Clutch..._JS_Parts.html (does not fit on schwinn with 79cc hf predator)
b.) purchased also from sick bike parts "Shift Kit Conversion Assembly" cost me with shipping $60.45 WILL TEST AND SEE WHATS' UP
21. Sprocket Adapter (Clams Shell Small- CSS) $75
http://www.ebay.com/itm/Sprocket-Hub-Adaptor-Custom-Motorized-Bike-Kit-Bicycle-Motor-Moped-Part-CSS-NEW-/261256037444?pt=Other_Vehicle_Parts&hash=item3cd412c444&vxp=mtrused it on my electric mtb Genesis 29nr and now on this one, got many miles on it and about 4 years
22. 44 Tooth Rear 9 Hole Sprocket For Any Motorized Bicycle Bike $15
(any bigger than 44 tooth will make chain cut into frame)
23. 56T Sprocket Rear for Bike $25 (not recommended for this bike)
24. the chain #35 Chain, 10ft. ebay Price: $16.00 this is a must
25. the chain #41 Chain, 10ft, ebay 0410 Price: $16.00 this is a must
26. Standard Hard Plastic Saddlebags for Harley $300
27. 79cc predator engine $99
28. 4L GAS TANK $60 will build my own follow closely to see procedure tools equipment needed
29: APE hangers $20
30. ELECTRICAL SYSTEM AND EXHAUST $300
31. ENGINE MODIFICATION PARTS ONLY A MUST ITEMS $50
in addition; impact wrench, home depot drill press, hf metal cutter/circular saw, hf 90 Amp Flux Wire Welder some other tools and items
one thing leads to another
ref.. to build
carburator; http://motorbicycling.com/showpost.php?p=507192&postcount=75
fuel/gas tank home made; http://http://www.dotheton.com/forum/index.php?topic=6339.0
http://motorbicycling.com/showthread.php?t=17323
testing sprockets ratios
suggested by members
clutch sprocket 11 t
to jack-shaft sprocket 22t
jack-shaft to wheel 9t
wheel sprocket 54t
drive ratio 12
engine rpm 3500 = 22.6mph
currently testing
jack-shaft to wheel 13t
wheel sprocket 44t
drive ratio 6.77
engine rpm 3500 = 40mph
Use the agk gear ratio calculator, you need something like ~ 12.*** something overall reduction...sounds like your geared a little tall. Might want to consider using something like a 56t sprocket rear sprocket.
Also I'm not sure if they make sprocket adapters for the multi-geared hubs, there usually made for coaster brakes hubs.
Plus any good sprocket adapter and sprocket together is easily going to cost 70+ after shipping.
Another route is finding a decent rear disc mountain bike rim and buying a sprocket from agk of your choice that mount to the disk brake hubs directly without any special adapters
I currently have a 52 rear sprocket on predator my build and I have to use a 28t jack shaft sprocket and a 9t output and it's still geared a little tall.
Did you remove the governor ?
I have a Riverside with a China Girl.
If you will be keeping the fenders I strongly suggest you beef up the stays and mounts. For my rear fender mounts I replaced the stamped stays with .375" round bar. It is a single piece that loops under the fender just like the original stays. I flattened the the ends to mount at the frame.
I also replaced the little fender tab (under the seat) with a much more stout steel angle.
The fender is rock solid now and I am not worried about it coming loose and ending up in the wheel.
All these pictures of Riversides has me all excited, snork.
First time I saw a pic of a kit, this is almost the exact bicycle I saw in my head. My mental image differed only in that the bike was all black.
Chris is so right about the fenders! (Great build Chris. I am gonna have to do a ChinaGirl RS build) They will try and kill you if left alone. The fenders, not the kits or bike. Although.......
We should start a Riverside club. Well, guess ya already did, lol.
.flg.
