So My main bearing on the magneto side went out . Started making a bad growling sound . I took the motor apart , removed the worn bearings from the crank , doesnt appear to be any damage to the cases or crank . Now what bearings should I get . 6202 C3 appears to be a correct engine bearing , or should I use a standard 6202 ? Any input is appreciated , thanks !
