how practical is putting a battery on your engine?
volcarius
just a thought i had, im nowhere near this in my build. id like lights that wont die on me during long rides or just for convenience so i thought what about a battery like a car has? anyway how practical would this be? and would it be difficult and very messy?
A car battery is just silly
Your best off using Lithium Ion rechargeable batteries for lights, It'll last you long enough for rides during the day, night and more
Just recharge at night
Theres many Rechargable LION bicycle light kits available today on Amazon
You can also use a 18v or 20v cordless drill battery to run light on your bike
Cordless Drill battery is small and holds enough charge for a couple hrs of light
But for a 2t motorbike I would buy a Lion Bicycle Light kit off AMAZON - They're crazy bright
Meh, I'm lucky and got a Whizzer Motorbike. It's got a 65w stator supporting a 12v 1.5ah battery
Start the engine and lights are always on just like a Motorcycle
High Low Bean Headlight
Fog Lights
Tail/Stop Light
Turn Signals
Horn
I also added spoke lights on the wheels, they change 6 different colors - 2 lights on each wheel = 36 color combinations
If ya ride at night, It's good to be seen
NOTE: Zip Tie the spoke lights to the spokes or they'll fly off at motorbike speeds
Fog Lights
Tail/Stop Light
Turn Signals
Horn
View attachment 118426View attachment 118424
i meant like cars have batteries so could I attach a battery that runs off the engine like a car does? obviously a much smaller one for just things like lights or light electronics, not like attach a car battery to my engine lol. your bike is super sick tho and super cool its lights run off its own battery
Sure you can hook up a 12v battery but ya gotta hook up a generator the runs off the engine to charge it and you'll also need a regualator
and that's a bit of mechanical engineering to accomplish that
Easiest thing to do for a 2t motorbike is get a rechargeable Lithium ion bicycle light kit off AMAZON
There is this Mini Gen that can be hooked up to your 2t motorbike engine to run a headlight and tail light
The only problem is it only makes 10w
There is alos a battery and regulator - charging system - that hooks up to this mini gen
my engine is a pred 79cc 4 stroke so im not sure if that thing is for 2 strokes only. the engine came with a pull start
I don't think there's a generator kit available for Predator engines to run lights on a motorbicycle
I'm not saying it can't be done but it would be up to you to figure it out, Someone somewhere has probably done it
But like I said the easiest thing to do is just get a good rechargeable Lion bicycle light it off AMAZON
They have rechargeable modern looking lights and Retro looking headlights
yeah sorry lol guess i should've said before
After some searching I did find a 212 predator flywheel that had a lighting coil to run a headlight on a motorbike
But I couldn't find that type of flywheel or lighting coil for a 79cc Predator -IDK if they make one - Maybe
Search and maybe you'll find it
OK after searching because I was curious
You can't hook up a lighting coil to run a headlight under the flywheel of a 79cc predator engine
AI explains
