Whizzer Custom Long Intakes
Tony01
1,869
1,987
sf bay area
Custom made mild steel long intakes for WHIZZER motorbikes.
21.5mm inside diameter, 48mm bolt spacing, 1/4” thick flanges, 2mm tube wall thickness. Inside welded.
i have 3.3” and 2.8” lengths. I can pretty them up like that one that I made for a guy, I’ll find the pic later
$40 shipped each
  • Like
Reactions: Sidewinder Jerry
Tony01
1,869
1,987
sf bay area
Ok so I made 3 and sold one, also sold flanges and tubing to a couple of people.
I measured up an NE-5 intake port and drew up a flange. The ports are .020” off center left to right so I made the flanges .010” off and was careful to make sure they were welded in the right direction. The port is also off from the line between the flange bolt holes and it is all correct. The step file is buried in my computer.
The flanges were lasered with big hole at .998” and chamfered significantly, a 1” ERW tube was then press fit and welded into the back chamfer.
I did these before I had a belt sander, so it took me a long time to sand them by hand on a piece of granite and I didn’t fill pinholes like I wanted. I can build them up and sand them down in minutes now if needed (it took me 4 hours of sanding like this to shave a 212 head .067” once).
I like my intake manifolds clearcoated. The only clear I have found that doesn’t allow the metal to rust is clear exhaust paint that I have to bake in the oven. It leaves
a pleasant amber shade.
wrench
844
1,205
93
So Cal
Intake manifolds look good for a 212cc , but not good for a Whizzer
Whizzer Vintage cyl intake manifold extends
Whizzer 1999 - 2004 WC-1 Cyl intake manifold extends
Whizzer 2005 - 2009 NE-5, NER, Ambassador Cyl uses a 1" intake spacer
A longer throttle cable will be needed and all the Whizzer guys I know with the NE-5 use an intake spacer 1" or shorter for best performance
Tony01
1,869
1,987
sf bay area
These are NE-5 parts. If the carb was right on the motor, it could interfere with the cylinder with its bowl due to the downward angle of the port.
Best performance for a flathead is the highest torque, which is not going to happen with a 1” intake. A longer intake will increase torque.
Flatheads have inherently bad flow. The guy I made this for had the 1” spacer and a 22mm carb which was too big for his 148cc so his intake velocity was even lower. A well setup carb is supposed to be ice cold during normal operation, instead his was BOILING the fuel because it wasn’t seeing enough vacuum.
My 148cc Briggs flathead was WAY faster; not even being a specially designed motorbike engine… just by having a properly setup engine intake and exhaust. I had a 16mm carb with a 3” intake and my carb was always ice cold.
Also that 1” spacer had a HUGE 1” thru hole so you can kiss port matching goodbye.
  • Like
Reactions: fasteddy
wrench
844
1,205
93
So Cal
No actually the aluminum spacer has a 19mm hole and some leave it as is while others will make the hole bigger to port match
PIc - cast iron Westman Cylinder
1" spacer is almost perfect, I shave mine down to 3/4"
3/4" with the insulation plate and gaskets makes 1"
@mason_man uses the same spacer but he makes his a little bit thinner 1/2" - 5/8"
  • Like
Reactions: fasteddy
wrench
844
1,205
93
So Cal
Whizzer guys buy the 1" aluminum spacer or make their own, It's not hard
1" - 1/2" intake spacer is what we use on the NE-5
This guy made his out of Pheonlic. It can be cut and shaped like wood, - super easy
Aluminum can be cut and shaped like wood too
Nice guy, he sent me one for free, It's already sized to fit my Westman cylinders
Tony01
1,869
1,987
sf bay area
Okay Wrench so what are you doing on my sale post ?
When did you intuit this was a topic to discuss intake lengths?
Go start your own thread on intake lengths, so we can keep discussing things with people not in the room.
Tony01
1,869
1,987
sf bay area
Just trying to give some helpful advice about Whizzer NE-5 Intake
EXCUUUUSE ME
Liar.
If you were sincere you’d edit your responses to nothing here and transfer them to a topic. I don’t see a topic started by you, so you’re a liar.
Test me a little more and I’ll make a video about our little feud and why you’re the POS I think you are.
Maybe when you actually build something then you can THINK to talk trash on a sale post (under the guise of being “helpful”) but you don’t build a goddammed thing. Sad old man, go away.
wrench
844
1,205
93
So Cal
Liar.
Impressive communication skills ya got there Tony
Name calling , threats, profanity and a promise of a hate video about me
You managed to break most of the forum rules
You got mental problems
BTW you've been Reported
Tony01
1,869
1,987
sf bay area
Hate is a strong word. I don’t hate you. I just want you to stay out of my business.
I guess I don’t need to make a video I’ll just say it. But arguments with you tend to get deleted here, but a video wouldn’t go anywhere. It’s not like I would share personal information, I don’t have it and have no interest in knowing more about you. The video is to have the offending posts publicly visible so it doesn’t get taken down.
Well you shared privileged information from a Private Message publicly on the other forum (that I wrecked bad) before I ever shared it publicly. I felt bad having shared it with you only and not the rest of the guys, so three days later I shared it here. Then just searched my name on the other forum one day 6 months later and your post came up. Had no idea you’d done that till then.
Most people wouldn’t do that kind of stuff. I let it go however.
Now you’re back in my business messing with a sale post.
Yep, I’ve got lots of problems now. If you know I have mental problems then why are you posting on my threads?
Why don’t you just leave me alone?
Tony01
1,869
1,987
sf bay area
I think your actions on here towards me could count as harassment, but I’m not going crying to mommy about it with a report button.
Just leave me alone man. I won’t post on your topics and I ask that you do the same. Or why don’t you just stay on motored, I’ll stay here. Can we agree on this?
Tony01
1,869
1,987
sf bay area
Tony I'll pray for you
Good bye
Why? You talk the talk but you don’t actually believe in the power of prayer. I got proof.
[Tony01’s] Intake manifolds… …not good for a Whizzer
Ever noticed how all the topics where you make a bold yet inaccurate statement then refuse to engage in discussion as to why your statement is inaccurate, all get shut down?
What’s your fn problem? Leave me alone.
wrench
844
1,205
93
So Cal
Correct context
wrench
844
1,205
93
So Cal
It works if ya work it
Since 2005 the top Whizzer Builders across the USA have done every speed mod possible to a NE-5 to see who can go the fastest and win races,
if a longer intake spacer would win a race I'm sure they would of done it
They choose to use an intake spacer that's 1/2" - 1" long
Just long enough so the float bowl don't get too hot
Carb also uses a heat insulation plate to prevent heat transfer
But hey maybe you know something they don't
I hope your long intake spacer out performs a short intake spacer and i hope you sell a million of them
i don't want to be rude But..,
If you would stop asking me questions, I'll be more than happy to leave this thread
Good Bye
