Exhaust port leaks
Wevil Kenevil
376
351
Sack a tomatoes California
When building my yd 100 lower and Ld100 top end , I wasn't paying attention to the thickness and diameter of the exhaust port and when I went to put my pipe on (f2 thrust) there was very little mating surface between the pipe flange and cylinder. 3.5 mm thick in some places.... ( No, there are no pipes that fit perfectly over this monstrosity of a hole. It's like a BT cylinder AND A YD CYLINDER had a messed up baby... It's not one or the other. )
So I suffered from horrible exhaust leaks. So what I did was take some metal putty from harbor fright and built up the area around the outside of the exhaust port.
If you can, do this before you run the head so that it's not all greasy and nasty and yuck so the putty sticks good and take a small file and rough up the area you are going to fortify around the port just for good measure!
I don't have any blow by or exhaust leaks now... Yay!
There may be other ways to do this but I am unaware of them.
Good luck!
Tony01
1,770
1,802
sf bay area
Good luck!
Exhaust pipe gaskets are specially made of a high temp composite material to not blow out with the heat and pressure. I’ve used copper sheet with success. The pipe and motor must be port matched for best performance.
