Wevil Kenevil
I know that most of you are aware of the slight but drastic differences in the different types of 50mm 100cc set ups but being new to this motor, I found it a hassle to learn the differences and their strong points and draw backs.
And PLEASE correct me if I am wrong but there are 4 types.
I originally bought a pexmor 50 mm 100cc kit. Well when I opened it up I was shocked to see what a horrendous job they did matching parts to their counterparts.
Beware, MOST OF these bicycle kits are just 46-47 MM piston motors honed out to 50mm. With NO real signs of upgrading the hardware to help
The problem: Thin cylinder walls and uneven hone. Mine looked like someone fell asleep leaning on the cylinder while boring it out.
Up side: it's cheap, and upgraded parts are readily available if you blow it up.
And You get to taste what the yd- Ld- and BT are about. Danger this is addictive !
2. The LD100 cylinders flood the market for 25 dollars and up depending on the package you buy.
I bought the LD 100 cylinder/ piston/ rings/wrist pin bearings/needle bearings , c clips/wrist pin and BEARING SPACERS***and gasket to replace the funky cylinder I got with the piece of crap pexmor kit ...
Only to find out the case that it fits is a bit larger than the standard c.g.
The bad thing about these is the mating surface on the cylinder for the intake and exhaust are EXTREMELY THIN. THE EXHAUST PORT ON MINE IS 3.4 MM THICK.
AND the hole is wayyy wider than any exhaust that I've seen other, than the inset flange on the BT which still don't fit.
Crappy design but does have G4 open ports and looks 1/3 bigger than its lil brother. And Unless there is some miracle work around for the exhaust that I am UN aware of I say skip it. The higher compression head cost me 60 USD for this. The ports don't match up to most standard parts.
(I don't see a draft save so I will finish this at my next free moment) sorry.
