Fave chain tensioner?
I bought the non-billet, case-mounted version because it seemed the most reasonable, but will entertain what experienced builders like.
The 4 bolt kit one on the pedal side and weld the small 1/2 on the chain stay... No tensioner on the engine side... Or a spring loaded one for a pit bike on the pedal side...
I've run the wiperman as a drive chain and has little resistance on the older 6mm grubee engines GT5 ... The new ones need the sprockets ground down and reshaped to fit by 1/16" ... The RK mini will out last several motors just to break it in
420 Is thick and heavy... Is going to robb a lot of power turning it and isn't that much stronger than a quality 410-415 chain... And those tensioner with the spring are more problems... You only need a tensioner with a swing arm with poor geometry
Ehhh mine been no problem for years but to each own :) I still go 30mph 420H chain with the HPcarb and chain tensioner...I have never had a 420H break ever!
