Havocdoesbikes
I was going to buy the bbr 50cc/49cc fourstroke bike engine kit on bike berry but I wasnt sure witch sprocket to get. How fast would I go on a 44 tooth? I have 26 inch tires and I weigh about 140 pounds.
Would it be better to buy a two stroke 50cc kit for cheaper?Welcome to the forum, I haven't built a four stroke so I can't help. I have two 48cc two strokes that will run 32 flat out on a good day, you should see at least 25-28 on a four stroke. My engines are ported and tuned for performance.
Along with the reputation of the company he's considering dealing with.There have been many members here that have bought the low end four stroke kits from ebay that the transmission failed quickly, a good quality kit that will last will cost close to twice the ebay kit.
Is bike berry a good and safe place to purchase these kits or is there somewhere more reputable?There have been many members here that have bought the low end four stroke kits from ebay that the transmission failed quickly, a good quality kit that will last will cost close to twice the ebay kit.
Thank you for the advice. Would this engine be more reliable?Here's one.
Ghost Racer 7G T-Belt Drive V-Mount Engine Kit Special Edition With Hu
NOTE: If you have a bicycle with a one-piece crank, you will need to buy a bottom bracket conversion kit separately. Please select the option above. *Bicycle not included with this kit. Ghost Racer 7G T-Belt Drive V-Mount Kit Special Edition with HuaSheng 49cc 4-Stroke Engine This kit features a...www.gasbike.net
Thank you for clarifying.Unless they have changed something in the transmission the website page gives a different reduction value for the transmission than their video does. The page says 6:1 where as the video says 6.83:1.
49cc BBR Tuning 5G Pull Start Bicycle Engine Kit- 4 Stroke
This Honda 4-stroke 49CC bike engine kit: when you want a tough, reliable engine that will go the distance with you. Shop our selection now!www.bikeberry.com
If you go by the video then using a 10/44 on 26" tires at 6800 rpm will give you a speed of is 17.5 mph. If you up graded to a 12/32 the speed at 6800 rpm would be 28.9 mph.
Stay away from this type of transmission, in the video, go with 7 or 8 G is the better choice.......Curt......... Gas Bike is goodUnless they have changed something in the transmission the website page gives a different reduction value for the transmission than their video does. The page says 6:1 where as the video says 6.83:1.
I wasn't personally recommending it just stating speeds for different drive ratios.Stay away from this type of transmission, in the video, go with 7 or 8 G is the better choice.......Curt......... Gas Bike is good
